OpenMP 4.5 SIMD
OpenMP 4.5 provides a standardised set to carry out loop vectorization. One can use simd directive to indicate that a loop should be SIMDized. As using these features should not bring too many modifications in a code and offer performance gains, we decided to test them on two real relevant cases. The code is available on github.
Tests description
Two cases are studied:
  • the inner product of two double floating point vectors
  • the matrix-vector multiplication still with double precision.
These two cases are applied to small size of vectors and matrices, typically for sizes between 8 and 64 elements per row (or column). Such cases are relevant when dealing with Discontinuous-Galerkin methods applied to either Maxwell equations or Navier-Stokes problems.
Benchmark setup
The hardware is Intel with 4 Cores i7-5600U CPU @ 2.60GHz featuring AVX2. For both cases, three kinds of strategy are followed:
  • pure c or c++ for loop code
  • use of openMP SIMD pragma
  • use of intel intrinsics (credits to blaze-lib developers).
In the case of the inner product, different containers are tested (std::vector, std::array, custom static aligned array). In the case of the matrix-vector multiplication, the extern loop is blocked in some functions. Moreover, only custom aligned array is used. Two compilers are tested:
  • GCC 6.1.0 with following options -O3 -mavx2 -fopenmp (one just needs to add -DCMAKE_CXX_FLAGS=-mavx2 when configuring the project using cmake);
  • Intel ICC 16.0.3 with following options -O3 -xHOST -qopenmp (one just needs to add -DCMAKE_CXX_FLAGS=-xHOST when configuring the project using cmake)
Results
Inner Product
The operation is performed 1,000,023 times, the vector size is 256.
GCC 6.1.0
Method Container Time (us)
C-loop std::vector 0.00132797
C-loop AlignedArray 0.00103898
Cpp std::array 0.00140897
Cpp std::vector 0.00123997
OpenMP AlignedArray 0.000403991
simd intrinsic AlignedArray 0.000212995
Intel 16.0.3
C-loop std::vector 0.000319993
C-loop AlignedArray 0.000551987
Cpp std::array 0.000229995
Cpp std::vector 0.000408991
OpenMP AlignedArray 0.000268994
simd intrinsic AlignedArray 0.000283993
Matrix-Vector Multiplication
The operation is performed 1,000,023 times and the matrix size is (M,N) = (64,64).
GCC 6.1.0
C-blocked AlignedArray 1.01194
C-pure AlignedArray 3.02451
omp-blocked AlignedArray 0.0128367
omp-pure AlignedArray 1.01515
simd intrinsic AlignedArray 0.00412391
Intel 16.0.3
C-blocked AlignedArray 0.00334492
C-pure AlignedArray 0.0042179
omp-blocked AlignedArray 0.00343892
omp-pure AlignedArray 0.00653285
simd intrinsic AlignedArray 0.0042989
Comments
As one can see, for both cases Intel compiler with the -xHOST option enables to vectorize the loops quite perfectly.
On the other hand, GCC does not behave so well especially when dealing with nested loops. Adding the line #pragma omp simd enables to recover good performance for the inner product but for the matrix vector product, even after blocking the main loop, the gain remains poor compared to the code using intel intrinsics.
Of course, such results need more investigations. We do not really know whether it is a bad use of GCC options (-Ofast works but its edge effects make it irrelevant in our context) or just a lack of performance of the compiler. It may also depend on the cpu architecture.
Let us also notice that without the -fopenmp option, pure C code provides better performance than with it. It seems that such a behaviour has already been identified for previous versions (see here).
Eventually, it is tricky to draw clear conclusions about the gain brought by OpenMP simd directives. Using Intel compiler with -xHOST option provides very good results without any change in the original code. Using GCC provides some good gains but theses latter require some code modifications and they are far from the optimal ones.
Comments and other tests are welcomed 🙂 !
About Thibaud Kloczko
Graduated in CFD, Thibaud Kloczko is a software engineer at Inria. He is involved in the development of the meta platform dtk that aims at speeding up life cycle of business codes into research teams and at sharing software components between teams from different scientific fields (such as medical and biological imaging, numerical simulation, geometry, linear algebra, computational neurology).
