Roland MDX 40A Numerical Milling Machine |
The milling machineg is located in the mechanical workshop (K103) in the robotics hall.
Only people trained to the use of the cutter by members of the technical team have freely access to it. |
The milling machine allows to make objects from wood (plain), plastic, it also to create PCBs.
The user guide is available here
Some Realizations
Calibration chart for X-ray | PCB for power blocs |
